Does anybody know any free screen recorders programs?
I need to take a photo of my PC screen, but also I want to record a sound of my PC. I am using Mac. Does anybody know a free screen recorder program?
See you!
See you!
Hi Abraham,
The best software for Mac users its absolutely free
Capture Me
Its very good software it capture screen and also recording utility for Mac with many options, floating capture window, many saving options and also have ability to resize you can say that is a open source for your mind peace.
1: Very fast screen capturing
2: safe files in many formats for example JPEG, PNG, TIFF, GIF or JPEG 2000
3: For window capturing adjustable translucency
4: Tremendous sound capturing
5: Shorts recording in MPEG-4
6: Mac Native- Cocoa written
Many other features just download free and enjoy using, There are many links to download from but if You want download from under mention URL
http://download.cnet.com/Capture-Me/3000-2192_4-10302571.html
If you are looking for a screen recorder, the best option is CamStudio Free Screen Recorder. It supports Windows XP, Windows Vista, and Windows 7. Windows 8.x and Windows 10 are not officially supported. With CamStudio, you can record all screen activities on your computer with audio and generate an industry-standard AVI video file.
The application also includes a built-in SWF Producer which can convert the generated AVI file into a small, bandwidth-friendly streaming flash video (SWF). CamStudio is an open-source screen recorder designed for the Microsoft Windows operating system and released as free software. Unfortunately, this application previously distributed malware and dangerous viruses with its installer. Here’s a little history. The original CamStudio application was developed in October 2001 by RenderSoft software.
In December 2002, the source code license was converted into the GNU General Public License with the release of CamStudio 1.8. The source code for CamStudio versions 1.0, 1.4, and 2.0 are still available at the SourceForge website. eHelp Corporation, which owns a rival product called “RoboDemo” and now called “Adobe Captivate”, acquired RenderSoft software in 2003.
eHelp Corporation released CamStudio 2.1, an updated version under a proprietary software license only. In this version, they removed the ability to create SWF files. A series of acquisitions led to the company being acquired by Adobe. There have been constant reports about malicious code contained in several binaries of the application.
The binary on the web page was reported in January 2014 to be infected with the Trojan “Artemis!0FEA2B12900D”. Currently, the application is clean and can be safely downloaded.
