Does Anyone Have A Key To This 0x88982f50 Error Problem?
Hey, I performed some work on my PC when I was stuck on this 0x88982f50 error. Is there a way to fix the 0x88982f50 error?
To fix the 0x88982f50 error, you will need to follow these steps:-
1. Right-click taskbar and then choose and click on the Task Manager option to open it.
2. Press on the Processes Tab along the top of the Task Manager screen and in the Processes Tab, find and press the button in the lower-left of the screen that says “Show processes from all users”. Press “Continue” at the UAC prompt that comes up.
3. Now, press on the column “Command the line” to sort the list and then find and locate: “C:\Program Files\Windows Media Player\wmpnetwk.exe”
4. Tab on it to select this process. Then press the “End
Process” button and then press “End Process”. It might fix it.
