Does anyone have leaked MacBook Specs?
Does anyone have the latest specs of MacBook which are leaked? And how different is this from previous version?
The new MacBook air most probably Intel ivy bridge processor, the 15-inch MacBook Pro is expected to be slimmer and thinner and this seems to be the case and another detail revealed is of a higher-resolution display.
Some of the claimed 15-inch MacBook Pro specs and features include a 2.6 GHz quad-core Intel Core i7 processor, 16 GB DDR3 SDRAM, 750 GB hard drive, 15.4-inch LED-backlit glossy widescreen Retina display with a resolution of 2560 x 1600 and AMD Radeon HD 7770M graphics processor.Â
Of course much of this could be different depending on personal configurations. Other inclusions detailed are a FaceTime HD camera, four USB 3.0 ports, Thunderbolt port, FireWire 800 port, Ethernet port, SDXC card slot and Bluetooth 4.0.
Dimensions of the 15-inch MacBook Air is said to be 13.52-inches x 9.26-inches x 0.74-inches and it weighs in at 4.7 pounds as opposed to the current MacBook Pro version which weighs 5.6 pounds.
Below is a leaked picture of the MacBook air specifications.
Since you are looking for the specifications of the latest MacBook Pro, here are the combined hardware specifications of MacBook Pro 13-inch and 15-inch with Retina display. The Retina display is set to 13.3-inch LED-backlit diagonally displayed with IPS technology for the 13-inch size and 15.4 on the 15-inch size. For the 13-inch size, the traditional screen resolution is set to 2560 x 1600 at 227 ppi and can be scaled down to 1680 x 1050, 1440 x 900, and 1024 x 640 pixels.
For the 15-inch size, the normal screen resolution is set to 2880 x 1800 at 220 ppi and can be resized down to 1920 x 1200, 1680 x 1050, 1280 x 800, and 1024 x 640 pixels. For the 13-inch MacBook Pro with Retina display, the price ranges from $1,499 to $1,699 while the 15-inch size with Retina display has price ranges from $2,199 to $2,799. For the 13-inch size, it ships with either Intel Core i5 dual-core 2.5 GHz [can be Turbo Boosted up to 3.1GHz] with 3 MB shared L3 cache or Intel Core i5 dual-core 2.6GHz [can be Turbo Boosted up to 3.2GHz].
For the 15-inch size, it ships with either Intel Core i7 quad-core 2.4GHz [Turbo Boost 3.4GHz] or Intel Core i7 quad-core 2.7GHz [Turbo Boost is up to 3.7GHz].
