Does Anyone Know how to access Sky drive remotely?
Hi there,
I have a small question. Does anyone have a solution as to how I can access my sky drive account remotely?
How do I map sky drive with my remote server so that I do not have to log in to the cloud, to view my documents? Someone please help.
I really need this working as I work remotely! Thanks.
Answered By 0 points N/A #98774
You should have a software to do this for you. This is the new version of Windows Live Essentials beta and Windows Live Sync.
The new version of Live Sync blends together features from both the old Live Sync, which sync folder between individual computers, and Live Mesh, which synced folders with an online desktop as well as other computers. The new Live Sync lets you sync folders and program settings between computers, and connect remotely to your Synced machines. It also lets you sync folders with your SkyDrive, so you can access files from anywhere. We’ll take a look at the features and how you can set this up on your computers.
Note: The new Windows Live Essentials beta only works on Windows 7 and Vista. Also, Live Sync is currently in beta, so only use it if you’re comfortable running beta software.
