Does Anyone Know How To Do A Copyright Symbol?
For my research paper, I need to use the copyright symbol, but I am not at all tech savvy. Does anyone know how to do a copyright symbol?
Congratulations on your research paper. It is a good thing you are using the copyright symbol, as copyright infringement is more common than you think. You can make this symbol in two easy ways:
1. Using the shortcut of alt symbols: Click on the alt gr on the keyboard (the alt present closer to the up-down keys). While holding it down, click on “c”. You should see the copyright symbol on your screen,
The next way needs microsoft office on your computer. Open microsoft word and open a new document. Click on insert from the menu bar and click on symbol. You will find a list of symbols displayed. Look for the copyright symbol and click on it. It will be added in the file. Now, copy the symbol and save this word file so that, whenever you want to insert it anywhere else, you can use it in the future also.
