Does Anyone Know How To Do An Electronic Signature?
I am going to enter a few business dealings to be done through internet. For security purpose I need an e-signature on few documents. Does anyone know how to do an electronic signature?
The best way for doing an electronic signature is by using the adobe reader. This is a third party software and you can download it through the internet. The reason I am recommending this particular software is that it has integrated support specially for e-signatures.
Once you have the software installed, open the document in adobe. Now, click on open sign pane as shown below: In the window on right side, click on “place signature” Now, you can either type or draw your signature (I recommend the latter) or use a webcam to click a picture, as well as use an existing one. Use the same steps for all documents.
