I have a Hp laptop with an Intel Processor. I am on Windows 7, and I am trying to burn a Windows 10 ISO file to a DVD. I am encountering the 0xc0aa0301 error, and I need help to fix it. Updating and reinstalling the drivers from the device manager did not work.
Does Anyone Know How To Fix The 0xc0aa0301 Error While Burning Image Files To Disc?
Try updating the chipset driver that is the most common cause for the 0xc0aa0301 error –
a. Go here
b. Click on Download.
c. Agree to the terms and conditions and continue.
d. Extract the Zip file.
e. Run the SetupChipset.exe file.
f. Complete the process.
g. Restart your device.
h. Try to burn the image.
Method 2
Use a third-party image burn software. There are many third-part image burn software that is free and safe to use. I will suggest you download from here
Install the software, and the process is the same as the default windows process.
Method 3
There are two types of DVD. They are DVD-R and DVD+R. The DVD that you are using might be incompatible with the work that you need to perform. In this case, I will recommend you to change your current DVD type to the other DVD type available.
