Does Anyone Know The Solution To The 0xc0000022 Error In Windows 10?
The Adobe application in my Windows 10 PC is not working. When I am opening the application, or documents using that application I encounter the 0xc0000022 error. Please help.
The 0xc0000022 error of Adobe occurs due to corrupt system files. Fortunately, here are some easy fixes.
Method 1
a. Press Windows + R on your keyboard.
b. Type appwiz.cpl and press enter.
c. From the list of applications, find MS Visual C++ 2013.
d. Right-click on it.
e. Click on Change.
f. Click on Repair.
g. Follow the same process for every version of MS Visual C++ 2013.
h. If the problem persists, follow the same steps to uninstall the software.
i. Go here and download the software.
j. Run the .exe file to complete the installation.
Method 2
c. Click on the option shown in the picture.
d. Enable Legacy Components.
e. Click on the + sign near legacy components.
f. Tick DirectPlay.
g. Click on OK.
h. Restart your device after the process completes.
i. The error will be gone.
