Does bitdefender internet security 2013 90 days trial works same like purchased?
Now bitdefender internet security 2013 90 day trial is available. I have downloaded it but yet not installed. I want to know if it provides the same protection like a purchased version for 90 days. I appreciate your comment.
Answered By 0 points N/A #157610
Any software that you download as a trial version has limitations. There are features that you cannot use and that are only available if you will purchase the software. For example, you downloaded a trial version of Bitdefender and you use it to scan your computer, it can scan your computer but will not be able to give you the full protection that your computer needs. The purchased version doesn't have limitations. It can give you security and protect you from any malware that your computer has. If you purchased Bitdefender that you can use for 90 days, it can protect your computer for the span of 90 days and after that you will be prompted because the purchased period is over.
