Does Bluetooth SIG inc have update for 3G?
I have a 16 GB iPhone 3G that has 412 MHz ARM 11 CPU, 2.0 with A2DP Bluetooth and iOS 4.2.1.Â
My Bluetooth function stopped working.Â
Does Bluetooth SIG INC have an update for my Bluetooth version?
Hi Halleleilani,
First of all I would like to inform you that if the problem is like while turning on Bluetooth, it turns on but never search for any device or it keeps searching on devices or other people able to find you over Bluetooth network but not able to transfer any data to you, then you must check the device settings and make it find able to other.
But now a days FTP or Bluetooth File transfer protocol is not available in iPhone. Its better to consult with your iPhone authorized service Centre or reseller about the issue.
Thanking You,
Margaret M Griggs
