Does chrome has a bookmark bar?
I have the solution for the problem that you are experiencing and lucky for you I am using Google chrome as my browser and I would love to help you out let me teach you. For you to see your bookmark page on Google chrome input these in your keyboard and press all at once ctrl + shift + b and then it will show your Google chrome bookmark page and now you can add or delete bookmarks like on Mozilla firefox. Have a nice day and enjoy your stay here and we will solve the problems that you are encountering.
In the address bar of your browser, there is a star icon (favorite icon) . To create a bookmark for the page which you are visiting now, click on this icon. Alternatively you can click on the wrench icon and then find it under “Bookmarks” menu. Click the bookmark and the page will open in your browser. There is also an option for customizing your bookmark settings. Whenever you click on the favorite icon ( ) in order to make a bookmark, a small window known as dialog box will open.
Here you need to confirm the addition to the bookmark. Here in this mini dialog box you can also customize your bookmarks.
There is a field labeled “NAME” where you can write your chosen name for this particular bookmark.
The bookmark will be added to recently used bookmark folder by default. If you want to place this page in another folder, click the “Folder” menu and select the location where you want it to be placed.
Then click “DONE” button and you are done! Remember: one bookmark can only be in one folder, and in one folder only.
Keyboard shortcut: to bookmark the current page, just press CTRL+D and then you can see the bookmark in the wrench icon menu and click on bookmark.
Thanks for answering my question Angelonfire. It was having a hard time to figure on how to bookmark page and it was easy as pressing Ctrl+D. O.o. Thank you very much. Techyv is a very helpful site.
Notifications
