Does cryengine support d3d or not?
Does cryengine support d3d or not? I am not an expert of this kind of matter and I need an excellent solution about this. How will I know if the compatibility error is about the operating system or on the software or application that has been installed in the computer? Help me about this guys.
Answered By 590495 points N/A #149558
It seems that you are experiencing an error or maybe some other kind of problem with your device or with your software. If the problem is from your device attached or connected to your CPU, try reinstalling the driver you installed with it. Uninstall first the device’s driver or program then restart your computer when asked.
After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use a disk utility application like Norton Utilities. Install the device’s driver again then see if it’ll work properly.
If the program was downloaded from the web, try visiting the website where you downloaded it then check its system requirements there. This will help you verify if you have a system incompatibility problem.
