I need a program to calculate resistor values.Â
Where can I download Electronics Assistant and is it a freeware?Â
Does it have an easy to use UI?Â
Will it give an accurate value for the different resistors?Â
Does it have a unit changer function and does it have a summary function for 2 or more resistors in series or parallel?
Does Electronics Assistant have a summary function?
There is such a program.
The Electronic Assistant 4.13 is one such application and is downloadable for free at this site
It’s equipped with a resistor color code calculator, capacitance, resistance and power calculations.
Also with this application, you can save and print the details of your calculations.
Calculation of 555 timer duty cycles < 50%
Calculate the power dissipation of LED resistor
Has an option to calculate the resistance for multiple LEDs in series
I think this program is the best tool for amateur electronics technicians, students, and especially professionals if they want to make their work a lot easier. Electronics Assistant is a kind of calculator that performs electronics-related computations. It offers resistor color code calculator, calculate the resistance, capacitance, power, and more.
The information of the calculations made can be saved in a file or printed otherwise. It can also calculate your preferred resistor values.
It’s actually a freeware that you can download from Electronics 2000 co uk Downloads. It doesn’t specifically say which version of Microsoft Windows it is designed for but I guess it will work on all Microsoft Windows versions.
Some of its features include the ability to calculate 555 timer duty cycles <50%, perform calculation on LED resistor power dissipation, add option for calculating resistor for multiple LEDs in a series, and fixed the previous version’s lock-up bug on the capacitor code calculator.
Watch How to use Electronics Assistant – tutorial video by TechyV to better understand how to use it.
