Does garmin support samsung wave 2
I use Samsung wave 2 and want to install garmin for GPS service. But I am not sure if garmin supports Samsung wave 2 handset. If it does then where can I find it for wave 2? Need your help.
Hello Sandra Taylor,
Samsung S8530 Wave II runs on Bada Operating System which does not support Garmin for GPS services. Since Bada OS is a small market, unlike Android or iOS, so not much is expected from it.
You should try Route 66 for navigation and map purposes.
Hope this will help.
Hy sandara taylor,
Actually the Samsung wave 2 gaming GPS application depend first on the region where you are and also the place from where you did buy your device.
Some places like US and Europe region different from the Asian regions. First check the region that the device did support and it is included in the device than start to ask about the application.
