Hello and good day TechyV users, Friends and to the community.
We know that HTML5 is the fifth revision of the standard HTML and as of December 2012, it is a candidate a W3C Candidate recommendation. Now here are my questions, is it available for making a free blog html 5? How can I do that. Any help would be nice.
Thank you very much.
Kelly Abbrahamson
Does html 5 available for making a free blog
Hello Kelly,
Yes, indeed you can make your blog with HTML5 now. Developers have developed lots of stuff for HTML5 and it is obvious that sooner or later the whole of the web would shift to HTML5. However now if you want to use HTML5 for your blog, the easiest way would be to use the ready made HTML5 templates and modify them as per your need.
These templates are designed such that they provide all HTML5 functionality and support HTML5 specific tags. You can find a few of the templates and details regarding how to build a HTML5 blog from scratch.
