Does iOS 5 better than Android?
Hi I need your help as I am in a dilemma in choosing the best OS. Should I go on with the iOS 5 or switch to Android. Please share your thoughts and suggest to me the best course of action to take. Thank you.
No don't go back to android…. Their updates are way too scattered and the software is really buggy. iOS 5 from Apple always put out an update 20 x faster than Android does.
iOS 5 is the Apple product and on the other hand Android is Google product, It depends on your choice, whether you are using that operating system for business purpose or for just for entertaining purpose. If you want a device for business purpose then iOS 5 would be suitable as it would be much more secure than Android, however it costs a little bit expensive. On the other hand Android which is open source and is free for every one.Â
