devis devis
30 points
Posted on - 05/23/2013
After using a long time my ipad mini is getting slower. Does ipad need disk clean up or defragment ? If so give me some advise how can i defrag or cleanup my ipad. If there are any apps or software give me that apps link.
Does iPad need disk clean or defrag
Hi Davis
Your system should be saturated. I can advise you to reboot your iPad, delete unused files to save memory, Update your iOS, backup your iPad using icloud That should help it to be more faster.
After all those steps, if it is still slow, you should contact Apple customer support.
Thank you
Hi Devis,
The usual ways of optimizing your iPad is by not filling up all the memory space available from your memory capacity, this will ruin your memory affecting the performance of the device, another thing is that it must have a task killer so that it can refresh the memory usage of the device.
If you haven’t restarted your iPad mini for a while and you just keep on charging it when the battery starts to become low, try rebooting your iOS device. It is a good way to freshen up the system. Also, check all the apps running in the background. If you have different applications currently running but you are not using any of them, exit the apps you know are not important.
This way you are not only speeding up your iPad mini but will also reduce the device’s battery consumption by terminating unnecessary applications. Another way of speeding up your iPad mini is to update to the latest firmware. To update, navigate to Settings then select General tab. Tap Software Update.
If there is an available update, follow the instructions to download and install the update. You can also improve the performance of your iPad mini by deleting less important apps. This is necessary if you have very little space left in your storage especially below 1 GB. To view your usage, go to Settings then select General tab.
Tap Usage located on the right side. Aside from that, emptying the cache of your web browser can add improvement to your device. Your web browser is another app that consumes space in your storage as you browse different websites. Clearing the cache can add a slight improvement to the device.
To empty the cache, go to Settings, Safari, and then tap “Clear Cookies and Data”. Tap Clear when you are prompted.
