Does launcher make any difference to my android experience
How do I personalize my launcher? Most of my friends are now using many different launchers and to them, it's an expression of class. Now I want to make my android device the better. Which launcher should I use from Launcher 8, Apex launcher, Go launcher or other launcher available in the market? Also, how do I customize it to my taste?
Answered By 0 points N/A #191360
Yes, you can personalize the launcher it is easy to personalize the launcher every launcher provide the customer to personalize ability. So you can install Nova, Aviate, Apex etc. They all have customization you home screen and other features.
Go Launcher is now a day going on top.
You can download any of the launcher from the store present in your mobile and they all are free to download.
Answered By 590495 points N/A #314498
The term “Launcher” is the name given to the part of the Android user interface that allows users to customize the home screen, start apps, make phone calls, and perform other tasks. A native Launcher is built-in to the Android mobile operating system.
But if you want to change the look of your interface, there are a number of Launchers available for download on the Google Play Store that can help you change the look of your screen. Try the following Launchers on your Android device and see which one is better:
  • ADW Launcher 2 – the latest version at the moment is 2.0.1.70. It requires Android 2.3 and higher. This will be the final release of ADW Launcher for Android 2.3.x and earlier.
  • GO Launcher – latest version at the moment is 3.101. It requires Android 4.1 and higher.
  • Launcher 8 WP style – latest version at the moment is 3.4.9. It requires Android 4 and higher.
  • Apex Launcher – latest version varies by device.
Note: all Launchers make your phone look great but before installing one on your phone, do check and read the many feedbacks from users who have tried it. I have seen so many negative feedbacks from great looking Launchers.
