Does Lenovo g650 have upgradeable hardware?
Can I upgrade the hardware of my Lenovo G650? I currently have a Core i3-380M 2.53 GHz, 3 GB DDR3 RAM, 500 GB HD. Can I upgrade this to 4GB DDR3 RAM, 1 TB HD? Can I also upgrade the video card? Thanks.
Hello Louise,
Any laptop can be upgraded if you can get the right parts. The Lenovo G650 can have it's RAM and HD upgraded from 3 GB DDR3 RAM to 4 GB DDR3 and it's 500 GB HD to 1 TB. The video card is also upgradeable. To find the right parts and replace them you should take the laptop to a technical shop which can replace them for you. If you want to replace them by your own you will need to be extremely cautious and if you don't know the interior of your Lenovo and what everything is you might harm it.
Notifications
