The Lenovo YOGA Tablet 2 Pro is a highly expected unique piece of work with a 13.3-inch display with its own projector and the world's first tablet-based 5-watt subwoofer. Now is it really true that with this tablet, Lenovo has made a radical change a whole different ball-game making it the sharpest device on the block. Does Lenovo YOGA Tablet 2 Pro 13.3-inch display bring 221pixels per inch?
Lenovo YOGA Tablet 2 Pro:
Yes, Lenovo YOGA Tablet 2 pro have a 13.3 inch display with 264 ppi. Lenovo YOGA Tablet 2 pro will be the first tablet-based 5-watt subwoofer.
Hardware:
• 13.3 inch 2560*1440 IPS LCD display.
• It bring 221ppi.
• We can correct color at all angles.
• Hinge at the back of the Lenovo YOGA Tablet 2 Pro is a fine piece of hardware. We can easily rotate it at 180 angle.
Yes Lenovo YOGA Tablet 2 Pro display brings 221 pixels per inches approximately. But I do not sharpest device because the iPad Air 2 has 264 pixels per inches. But its own projector and 5 watt subwoofer make it separate from the others. So you have a choice if you go on display, then iPad Air 2 Will be best.
