Does Mac support Samsung MultiScreen software
I have used Samsung MultiScreen software in Windows Vista without having any problem. Does mac support Samsung MultiScreen software? If it supports what is the procedure.
ThanksÂ
ThanksÂ
Samsung MultiScreen software is working with only Samsung monitors. But, Mac support's Multi Screen software, Mac has more than 30 software’s for Multi Screening. Like AirPlay Mirroring, Secondbar, Swapp
If you are looking for the Multi Screen software for Mac, you can download the Multi Screen software from below mention link:
http://mac.appstorm.net/roundups/utilities-roundups/30-apps-for-your-multiple-monitor-setup/
I hope it will helpful. Thanks!
Hi George,
Please note that. If you are using your Samsung monitor as an extended or secondary monitor and if you have cut it of from the source then Samsung multi-screen software would not function however you can use it if your primary monitor is a Samsung.
You can download the software while clicking below and follow the advice as expressed above.
http://multiscreen.software.informer.com/
Hope this helps.
Thanks
Baker
