Does Malwarebytes Anti-Malware Remove Viruses From My PC?
Hello everyone,
I want to install Malwarebytes Anti-Malware on my PC. I’m not sure if it will remove the Viruses from my PC or not. I have got mixed reviews on its Official Site. Does Malwarebytes Anti-Malware Remove Viruses from my PC?
Answered By 0 points N/A #166293
In my opinion, it is a good Software that you can use to remove the Malicious Applications from your Computer.
All you have to do is Update the Malware and Virus Database regularly, so that you keep the Anti-Malware Program up-to-date.
An Anti-Malware Software is only effective its Virus Database is Updated.
If you want, you can download the Trial Version from
https://buy.malwarebytes.com/us?c=cj.
