Does memory handling issues affects the computer performance?
        While doing programming does improper memory handling affects the performance of computer? for example if you do not free the allocated memory while doing programming in c/c++.
If it really affects the hardware/ computer performance a big deal then what's the solution? because during practice i do not generally handles memory properly.
