Does the mpeg-2 keep the interactivity of the Powerpoint presentation? I have a kiosk that is touch screen which allows viewing of mpeg-3 and picture files through a CF card. Do the button animations stay as is, and does the viewer have a full control over maneuvering between the slides?
Does mpeg-2 keep the interactivity of Powerpoint presentation?
Hallo Josh Bernard,
It will depend on which version of PowerPoint you are using. If you are using PowerPoint 2010, then no problem, it will keep the interactivity on your PowerPoint presentations as you want and you can open the mpeg-2 videos by simply going to the files option in the PowerPoint menu and then from the drop down menu in the window that comes up after clicking open you will select the type of file to open with which is mpeg-2 i this case.
As for the other older versions, I do not have an idea if they will offer you the same service, but you can try ms PowerPoint 2007 which seems to have features close to those of ms PowerPoint 2010.
Hope this helps.
__
Regards
Mahesh Babu
