Does MSI’s Wind Top AC1900 will also be available in Philippines?
I am working online with a lot of projects. But since I am using desktop with 4 GB it gives hard time and drives me slow.  I’ve learned MSI Wind Top AC 1900 All–in–One PC has an offered of more than 4 GB. But will this be available in Philippines?
Best Answer by mlvillapa
Answered By 0 points N/A #161761
Wind Top AE1900 is incorporated in design, choosing an stylish white with a glassy shape, which shows the convenience of contemporary personal image and the relaxation of home.
Furthermore, it is with the best computer features, such as immediate concept, low acoustics, and economical and 802.11 b/g/n WiFi ability so you may go easily in the world of the net.
Wind Top AE1900 is certainly prior to its time, especially with the touch screen technology operate delivers the world right between your convenience, included a helpful interface, all of the features are simply right within your understand. The 19 inches 16:9 display provides 160 levels of side to side broad range of visible entertainment.
It also carries on the light and intricacies style of the All-in-one sequence so you may enjoy all the independence for your workplace, maintaining things simple and versatile.
Buy Online At Here
Answered By 0 points N/A #161762
Hi Dolore,
MSI Wind Top AC 1900 All–in–One PC is now available in the Philippines, however, you can only get the PC with Network Essentials Corp. located at 173 EDSA CSP Building, Mandaluyong City. You can either call them at 632-721-1981, check their website: www.netessentials.ph or email them at [email protected]
Let me just advised that this PC does not offer more than 4GB of RAM yet (I have included the screenshot that shows this PC doesn’t offer more than 4GB of RAM). You can check the specification of this PC by just visiting https://www.msi.com/All-in-One-PCs/Wind-Top-AC1900.html. If you’re looking for device that can accommodate multi-tasking to perform well with your online project, you might want to consider getting the following PC:
* Wind Top AE2410G
* Wind Top 2410
* Wind Top 2420
All of the above models from MSI' All-in-One PC can be upgradeable to up to 8GB of RAM.
For other specification that you would also like to check, you can just shop around at this page: www.msi.com/product/aio
You can also check other manufacturer that can offer more than 4GB of RAM like HP, Dell, IBM or Lenovo
-lorie
Answered By 10 points N/A #161763
Hi there,
MSI Wind top AC 1900 AIO is compact computer, so it easy to move the computer. But it is not so efficient to do so much hard work. As you want to work online none stop and fast but it has not so visible with this AIO. This AIO do not have 4GB RAM build in. It usually have 2GB RAM so it will not be so much fast. Now I think it will be better if you customize your present computer. Also this AIO’s processor is Celeron. So over all it is not that good for fast and none stop work.
Thank you,
Riley weaver.
