Does My fax have electronic signature?
Hi guys.  I need some feedback here.  I have a 32 GB iPhone 4S with iOS 6 and I would like to try the free version of My Fax.  Does it have security with SSL encryption and electronic signature?  Thanks in advance.
Answered By 25 points N/A #151999
MyFax for iOS can help you manage your documents anywhere you are, create, send and receive faxes using your iPhone device. It can create and send faxes, snap a photo of your document and MyFax will improve the images and then merge it. And fax it just the same way you are doing on a regular fax machine. You can also send faxes from your iPhone or MyFax contacts. However, it doesn't support digital signatures. If you want this feature, you can try the Editor's Choice eFax. It has a free fax storage, hude file transfer and it support digital signatures. Get more information from the link below:
– eFax: Mobile Phone Fax Application
