Does Netscape 7.2 support Windows7?
Netscape is an internet browser where it will support almost all the version of windows.
The thing here is you need to choose which version will suit your requirement best. Based on your question netscape 7.2 supports even for windows 7 also.
Just run that in compatibility mode. It will work as if it is in windows XP or windows vista.
The basic thing that you need to know about windows 7 is its compatibility feature which will allow you to run almost all the software as it works for xp and vista.
Just use that compatibility mode where ever it is required.
If you are wondering if installing Netscape Browser will be compatible with your operating system, I think there should be no problem.
But Netscape 7.2 is a bit old and if you want to install this web browser, it would be best to install the last and latest version, Netscape Browser 9.0.0.6. This version supports Windows 95, Windows 98, Windows Millennium, Windows 2000, Windows XP, Windows Vista, and Windows 7. To download, visit Old Version of Netscape Browser 9.0.0.6.
The Netscape Navigator 9 was a web browser developed by Netscape Communications which is a division of AOL. It was on June 5 of 2007 that the application’s first beta was released followed by Beta 2 on July 12, and Beta 3 on August 16.
But on December 28, 2007, the developers of Netscape announced that AOL would be stopping the development of the web browser on February 1, 2008. When January 28, 2008 arrived, they adjusted this date and move it to March 1, 2008 and they also offered support for relocation to Mozilla Firefox and Flock.
Thanks guys for your kind help.
I am really glad to know my desired answer by going through your comments.
Although I was interested in installing Netscape 7.2, I had no idea about its latest version. Since I read your comments, I could easily recognize the latest version, Netscape Browser 9.0.0.6.
I can’t image how easily you described everything in short! With good grace I can only say THANKS guys.
Sharath, your provided free download link was not expected but I used it and succeeded by applying your tips.
Also thanks techyv.com for publishing this post.
Now, the latest version of Netscape is already running on my Windows 7 PC without any errors.
