Does nokia 5530 have GPS ?
was wondering if the nokia 5530 has GPS installed on the phone its self or i have to download it myself and if i have to download it where can i get it ?
Dear,
Nokia 5330 has build in GPS device with Nokia maps. In order to use the software you need internet connection on your phone and maps application. You can use Nokia maps or Google maps on Nokia phone. If you do not have maps software visit Nokia official website or Google it for Nokia maps. Google maps are also available on Google.
GPS is the device and you need maps software for using it.
Thank You.
GPS stands for Global Positioning System.I helps to find your route to your destination while traveling. 3G is a mobile broadband service through which you can get fast access to internet on your 5530.However, 5530 has Wifi which is even faster that 3G.
More See:http://madelifebd.blogspot.in/
Dear,
The Nokia 5530 have not GPS connectivity device but Nokia 5530 have GPRS. You can also use EDGE (EGPRS) for data collection. Nokia 5530 is not 3G mobile. If you want to web browsing please use WAP 2.0.Â
Thank you.
No, unfortunately, the Nokia 5530 has no GPS. Here are the phone’s specifications. The Nokia 5530 XpressMusic is a discontinued 2G Smartphone operating on 2G network band using GSM technology. It was unveiled to the public on June 2009 and released on August 2009 measuring 104 x 49 x 13 millimeters and weighing 107 grams. It uses mini-SIM card.
It has TFT resistive touchscreen display with 16M colors at 360 x 640 pixels screen resolution with handwriting recognition. It ships with Symbian 9.4, Series 60 rel. 5 powered by 434 MHz ARM 11 processor. It supports microSD expandable up to 16 GB. It runs on 128 MB SDRAM with 70 MB internal storage. The primary camera supports 3.15 megapixels with AF featuring LED flash.
It can record video in 480p at 30 fps. There is no secondary camera. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g, Bluetooth 2.0 with A2DP support, stereo FM radio with RDS support, and microUSB 2.0. There is no GPS supported. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports WAP 2.0/xHTML and HTML with Adobe Flash Lite support.
It runs on removable BL-4U Li-Ion 1000 mAh battery with standby time up to 336 hours and talk time up to 4 hours 54 minutes. It is available in red on black, blue on white, grey on black, pink on white, and yellow on white colors.
