Does Nokia stands in the customer war???
The email and calendar functions of Nokia lumia 900 are not properly working. Customers are challenging on their software. Can Nokia get up to the mark by changing or updating the software?
Dear Rvtjallena,
Its obviously Nokia is one of the best retailer of phone device. They are ruling the world telecommunication with an ace performance. They are providing one of the best technical supports as well. Now a days, we can see some technical error, some sort of limitations in the devices, slowness of the operating platform, few facility and update problem.
Nokia is frequently updating their patches for the phones software, by which you may able to solve your problem. Nokia has the largest forum support and a huge number of people still holding their faith in it. So for now they may stand for the customer war.
Here are the specifications for the Nokia Lumia 900. The Nokia Lumia 900 Smartphone is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on February 2012 and released on May 2012. It measures 127.8 x 68.5 x 11.5 millimeters and weighs 160 grams. It uses micro-SIM card.
It has AMOLED capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass with Nokia ClearBlack display support. It runs on Microsoft Windows Phone 7.5 Mango powered by Qualcomm APQ8055 Snapdragon S2 chipset, 1.4 GHz Scorpion processor, and Adreno 205 GPU. It doesn’t support microSD. It runs on 512 MB RAM with 16 GB internal storage.
The primary camera supports 8 megapixels with Carl Zeiss optics, dual-LED flash, and autofocus. The primary camera features geo-tagging and can record video in 720p at 30 fps. The secondary camera supports 1 megapixel and can record video in VGA at 15 fps.
It has 3.5-millimeter jack with Active noise cancellation with dedicated mic support; Wi-Fi 802.11 b/g/n; Bluetooth 2.1 with A2DP and EDR support; GPS with A-GPS and GLONASS support; stereo FM radio with RDS support; and microUSB 2.0. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML. Java is not supported.
It runs on non-removable BP-6EW Li-Ion 1830 mAh battery with standby time up to 300 hours both on 2G and 3G. Talk time is up to 7 hours both on 2G and 3G. It is available in black, cyan, white, and magenta colors.
Regarding with the email and calendar problem, I guess it is no longer the original Nokia developer who is responsible for the problem because this model is already running on Microsoft Windows. Microsoft should be the one handling the problem and provide the solution.
