Does the Original system image change after updating
What happens to my original system image if my system makes an update and will it still function properly?
Hi
When system updates it overwrite the original system image. Before updating you can take back up of original system image from which you will be able to recover your old system image. After overwriting the old system image because of the update it will function properly. Windows always take updates automatically if the update option is not off. But if you are very much ware about your original system image than create a system image back up and keep on a DVD. In case you want to go back to your original system image then you will be able to retrieve it from the DVD. After restoring it will also function properly.
Best of luck
Your System images will be upgrade if you will upgrade your system. It will function better after up gradation. To prevent your images make a backup first then upgrade system.
Notifications
