Does the Padphone synchronize when the phone is in the dock?
Tahjiaw 0 points N/APosted on - 06/10/2012
When using the ASUS Padfone, while the phone is inside the dock, does it synchronize with the phone as to allow the regular phone functions such as calls and text messages to still operate through the padphone?
Hi there!
Yes, the padphone, even if it is docked in the tablet, it can still function as your regular phone. It has a stylus that can also be used a Bluetooth headset so it is easy for you to make a call or to take a call.
Features of the padphone are as follows:
As a smartphone (Android), the display is 4.3 inches.
It can dock inside a tablet measuring 10.1 inches
Lastly, the tablet can be docked into a keyboard.
The concept is really very innovative.
If you want to check out more about the padphone, see the video below.
1....
