Does Photoshop cs6 bible PDF worthwhile for graphic designers?
I am a graphic designer. I am very skill full in photoshop, illustrator and Corel draw. I will be receiving photoshop cs6 bible pdf as a gift from a friend. I know graphic designing by experiences by using such software, no by reading books. I just want to know will that book well for me. Does it add value to me?
Best Answer by Marvin M Calderon
Answered By 20 points N/A #130104
Hi Mary,
Adobe Photoshop CS6 bible is a great book to read and keep for further use. It’s a real manual for the program it takes you from A to Z in Photoshop world. It's designed to give you all the information you need whatever your level or purpose in Photoshop are. Check this link to know more about the book.
Answered By 55 points N/A #130105
Hello Mary G Greaney,
                      If you want to learn Adobe Photoshop then you can also go to Lynda website and can get many things from there all you need is to go there and search for the right category. But the book about which you are telling is a good book and it contains many references  of the things. So i hope that you can get much more knowledge from that book all you need is to read it with some practical work.
