Does a PS2 perform faster than a USB?
I normally use a plug ps 2 mouse and i want to try out the USB plug for the mouse. Will it slow down in terms of performance or will it be slower? Which reads faster ps2 or USB?
Hi Mr. Walter Neff,
I have seen a lot of answers in different forums with the concern that you’ve posted here. I think that it is a better way if you go visit the links below for more information.
Hope that would help you a lot.
Thanks and more powers.
As it concerns with using mouse it does not make any deference to use ps2 mouse or USB mouse because mouse need to transfer very less amount of data. The only problem can rise that different os do not support USB mouse. ps2 mouse has pin which can break and create problem.
Thank you
