Does safeguard easy 4 support 64-bit operating systems?
My OS was windows 7 32 bit.
But I migrated into Windows 8 64-bit operating system.
I tried to install safeguard easy 4 into my new OS, but it did not work. Does safeguard easy 4 support 64 bit operating systems?
Answered By 0 points N/A #133669
Hi Matland,
Safeguard easy 4 works with both 32-bit and 64-bit for Windows 7 and Windows Vista SP1+ with a Minimum 300 MB disk space and 1GB Memory. But sadly, its not compatible with Windows 8.
For using safeguard after installing Windows 8
You’ll need to install Safeguard Easy/ Enterprise version 6.1 and above. The Installing process is just the same with installing it on earlier Windows operating systems
NOTE: SafeGuard Easy/ Enterprise 6.1 is not supported on Windows 8 RT platforms and SafeGuard Easy/ Enterprise Device Encryption 6.1 doesn’t work on Windows 8 Storage Spaces.
Good luck
