Does Samsung Europa(upgraded to v2.2 froyo) support Adobe flash player
Hello Floyed,
I hate to be the bearer of bad news but your Samsung Europa smartphone does not support Adobe Flash Player.
Adobe has dropped any kind of support for Flash Player.
However, Android 4.X versions is supported.
If you still want to install Adobe Flash Player, here is the link for you:
Just click it and it should download .apk file. Transfer it to your smartphone by USB cable and then install it through the phone. Restart your smartphone.
Adobe Flash Player should work now, but the performance depends on your phone's hardware specifications.
The Samsung Galaxy 5 I5500 has many other names like Samsung Galaxy Europa and Samsung Galaxy 550. It is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies measuring 108 x 56 x 12.3 millimeters and weighing 102 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 240 x 320 pixels screen resolution with TouchWiz v3.0.
It ships with Android 2.1 Eclair upgradable to Android 2.2 Froyo powered by 600 MHz processor. It supports microSDHC and has 170 MB internal storage. The primary camera supports 2 megapixels and 320p video recording at 15 fps. There is no secondary camera. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support (Android 2.2), Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0.
It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML. It runs on removable Li-Ion 1200 mAh battery with standby time up to 521 hours on 2G and 375 hours on 3G. Talk time is up to 9 hours 30 minutes on 2G and 6 hours 30 minutes on 3G. It is available in black color.
1....
