Does sharing internet make the internet slow down on one computer?
Yes, it definitely could make your connection slower because they both share one IP address. Meaning, they only have one connection and every computer competes on other computers to connect to the internet. It is good if you have good and fast internet connection to produce good connection.
For more info. Visit Download Link
Hello Dear,
Surely, sharing internet connection will slow down the internet access speed. However, speed slow down depends on many factors. If you are using a broadband internet connection and all the persons sharing internet connection for only browsing purpose then it is sufficient. But if the users are downloading and heavy videos and images then it will quickly slow down the speed.
Patrickk wilkins
Yes, sharing the internet connection can make your connection slow but the speed should depend on the activity on the other computer. If both computers are just browsing the internet and neither of the two is video streaming on YouTube, for example, you probably won’t notice any slow down on your connection.
But if the other computer is downloading a big file or watching a video on YouTube, your connection will be greatly affected. Even if the other computer is not directly sharing the internet from your computer like if both computers are connected on the same router, this also applies.
