Hi. I plan on installing Linux Slackware ARM 14.0 but I have some questions first. Does it support Nvidia Tegra CPU and what program would the first to run besides the Linux kernel? I need some info on Slackware Linux. Thanks in advance.
Does Slackware linux support Tegra?
Hello Hanley,
How are you?
Hope you are doing well.
Coming to query about Slackware Arm 14.0 , yes it supports Nvidia Tegra CPU (TrimSlice).
Other than that it also supports QEMU emulator. You can get more information on how to install.
Hope this will answer your queries .
Thank You!
To install Slackware Linux 14, go through the following checklist:
1. Make sure you have at least 1 GB of RAM and 5 GB of hard disk space
2. Choose the software packages you want to install
3. Select the boot disk
4. Select the root disk
4. Partition the hard disk
5. Run the Slackware setup program.
