Does Someone Know How To Convert 3Ds To NDs? Please Help
I am an expert in Autodesk 3Ds Max software. I make integrated 3D simulations using the software. I want to convert the 3Ds models to NDs models. Does someone know how to convert 3Ds to NDs? Please help.
Answered By 0 points N/A #289919
Since you are an expert in Autodesk and 3Ds software, I’ll give you two alternatives to solve your problem.
1. Online solution. Just google ‘convert 3Ds to NDs online.’ There are plenty of sites that help you convert 3Ds to NDs online on their servers. You need to upload your 3Ds model on their website.
2. Offline solution. Install a program called ‘Quest NDS migrator.’ It has a very good graphical user interface to help you with your problem.
