Does Sony RX100 has a panoramic views feature?
I was researching for the features of RX100 over the Internet and I do not know if that latest model has a Panoramic feature.
How many hours the battery can last? Is RX100 shock proof?
Jay P.
Jay P.
If you are referring to the Sony Cyber-shot DSC-RX100 digital camera, then here are its specifications. The camera supports 20.9 megapixels with 1.0″ CMOS sensor (13.2 x 8.8 millimeters). For still images, it supports JPEG and RAW formats while for videos, it supports MPEG-4 AVCHD. It has a maximum resolution of 5472 x 3648 pixels at 1:1, 3:2, 4:3, 16:9 aspect ratios with built-in flash.
It features optical and digital image stabilizations. Optical zoom is supported at 3.6 times while digital zoom is at 7.2 times. The camera supports SD, SDHC, SDXC, Memory Stick Duo, Memory Stick Pro Duo, and Memory Stick PRO HG-Duo memory cards.
It supports video recording up to 29 minutes in 1920 x 1080p at 60 fps, 1920 x 1080i at 60 fps, 1440 x 1080p at 30 fps, and 640 x 480p at 30 fps NTSC. For connectivity, it supports one Micro HDMI D port and one USB 2.0 port. It runs on NP-BX1 rechargeable Lithium-Ion battery. It measures 101.6 x 58.2 x 35.9 millimeters and weighs 240 grams.
It costs around $448 at BHPhotoVideo.com.
