Does stellar phoenix remove bad blocks from hard drive in windows
I am using windows 7 ultimate in my PC. I have found that there are some bad blocks in my PC's hard drive. Can I remove those bad blocks using stellar phoenix? Does stellar phoenix remove bad blocks from a hard drive in windows?
Thanks
Answered By 0 points N/A #197505
Hello
Stellar recovers only your files which you damaged or deleted. If you have problems with your hard drive then you should visit official page of your hard drive manufacturer since every manufacturer have their tools to determine errors and fix them. If you don't know your hard drive manufacturer then you should use built in Scan Disk tool in windows. It scans your hard drive and if errors are found it make a record, so next time that damaged sector won't be used.
