Does VLC support 3d view?
Hello techyv experts,
I have a simple question
Does vlc support 3d view? how can i enable it? Or does VLC have a different software for it?
How does this work with the VLC player showing 3D on a normal monitor thats LCD or LED
thanks
Answered By 30 points N/A #88695
Hello
Yes, VLC support 3D view . to enable it make the following steps :
1 – Open VLC media player .
2 – Select Tools .
3 – Select Effects and Filters .
4 – Choose Video effect .
5 – Choose Vout / overlay .
6 – You will see a box for wall .
7 – Click on this box and rearrange row 3 and column 2 .
8 – Now your VLC appear in multiple view .
9 – Choose one of these windows and make it full screen .
10 – Get the 3D effect .
I hope these steps help you solve the problem .
