Does Windows 7 Ultimate support SQL server 2000 Express?
I want to know about the compatibility between Windows 7 Ultimate and Microsoft SQL Server 2000 Express. Can I download and use SQL Server 2000 Express on my PC? If I can use it on my PC from where I can get the download link.
Answered By 0 points N/A #197543
To Bonnie.
Microsoft SqlServer 2000 Express   actually has known compatibility issues  with windows 7 ultimate. May be you try to fix with the 32 bit version of windows 7 ultimate as SQL Server 2000 is a 32 bit software. But with windows 07 64 bit version, that can not be done.
Have a look at the link below and go to the system requirements section.
http://www.microsoft.com/en-us/download/details.aspx?id=18290
windows 7 ultimate is not in the list.
