Does Windows XP have an option of Thumb Impression
Does Windows XP have an option to execute windows after taking thumb impression of user instead of password?. I mean to say that, system should not be started without the thumb impression of the user. Does this option available in Windows XP? If it exists what will be method to obtain this facility.
Answered By 0 points N/A #115011
Well it depends on your Machine you never mention about you PC are you using laptop or desktop computer while in many laptops there is an built-in option for thumb press or thumb impression you just need to press your thumb impression on it and i will work mostly in Dell or Hp Brands laptops having such kind of facility in laptops while Windows XP will be supported if your are using such kind of PCs other wise in desktop computers there is no built-in option or any kind of software which can be use as security lock in the startup. While there is option in windows XP for voice password you can use the voice password instead of thumb impression password.
