Does Windows7 have a Firewall? If not, which Third-Party Firewall should install?
Hey everyone,
It is an important requirement that a user should have a Firewall. Does Windows 7 have a Firewall by default? If not, then, which Firewall should I download to prevent Unauthorized Traffic to reach my PC?
Answered By 0 points N/A #120745
Windows 7 comes with a Firewall already. You don’t have to go for any Third-Party Firewall Application. Windows Firewall provides you the required security. You don’t have to worry about anything. If you want, you can install an Antivirus.
People get carried away in the favor of External Firewalls because they pop-up more frequently. But, Windows Firewall comes with Windows 7, and it performs its task silently in the background. There is no need to install an external Software.
