Doesn’t work instalar elusiva Java ubuntu
Hello everyone,Â
I need some help. I am using Java but my installer elusive Java Ubuntu is not working. I can't understand what is the problem with it. Can anyone help me?
Thanks in advance.Â
Hello everyone,Â
Thanks in advance.Â
Hi Young,
This could be a problem with the java version of your system. Please check what Java version your system is using. To check java version follow this step : RUN 'JAVA -Version', it will show you information about your java version, also make sure you have JVM running in the background to support your installer cause java should its own virtual environment and it does not depend on OS.
If you are running with lower java version then just update your version of java and that will solve your issue.
Thank You.
