Bertoy
Posted on - 12/05/2011
Hi All,
Please guide me to use this AIM 7.5 applications were I need to communicate with my friends. I’m using windows 7 starter in internet cafe when I’m trying to finish the installation of AIM then start, the error display in the screen.
I have no internet connection in the house that’s why I need to go to internet café.
Thanks everyone.
C:Program FilesAIMaim.exe
Windows cannot open this program because it has been prevented by a software restriction policy. For more information, open Event Viewer or contact your system administrator.
OK
Doesn’t start AIM in my PC
Just simply go to the administrator to your system and then just simply set the default  security level for the software Restriction Policies just simply disallowed the software and then just simply create a path rule and after that just simply set the security level to your system to Unrestricted the file and then simply you just configure the path rule to point to a mounted in the NTFS file from the system volume and then try this one check or scan the software if there an viruses too sure if there is infected file from software just simply check on that.
Ben
Since you are using a computer from an internet cafe, this situation is unavoidable due to the security purposes. Some computer cafe are blocking new files to be downloaded on their computers to prevent viruses and malwares. However, your problem can be solved by simply contacting the attendant of the cafe. All you have to do is ask permission from the administrator and if they  allow you to download AIM Messenger, you will not get this error again. Hope you'll be able to talk to your friends soon.Â
