Hi there,
When I tried to open Doge Coin this error appeared and it seems like I cannot make it work again. The reinstall is not working at all and I don’t know what I should do next. Any solution ? Please help me to make this works again.
Regards !
Runway exception
A fatal error occurred. DogeCoin can no longer continue safely and will quit.
EXCEPTION: 11DbException
Db::open: Invalid argument
C:UsersJaredDesktopDogeCoindogecoin-qt.exe in Runaway exception
Doge coin error while playing the game
It seems like they didn’t provide the information for the application’s system specifications so users can better check for the compatibility with their computers. If you already tried reinstalling it and it still didn’t work, try downloading the installer again to make sure you have the latest version. Visit Dogecoin Download. When downloading the Dogecoin wallet, select between the Dogecoin MultiDoge and the Dogecoin Core.
If you select Dogecoin Core, make sure to select the correct version for your operating system. If you have x64 Windows 8, you should download the 64-bit Dogecoin Core because the 32-bit is designed only for 32-bit operating systems. You can only install the 32-bit version on 64-bit operating system if no 64-bit application is available but since both x86 and x64 versions are available, you should download the appropriate version for your computer.
