I downloaded the latest version for my audio hardware and I have this error. I don’t know why is saying that I need the latest version since this is the only one that I found it. Can anyone help me to fix this? You know any other ways to download the latest version of drivers?
Thank you!
Dolby Advanced Audio
The current Dolby audio driver version is 7.2.8000.17 and the software application expects driver version 7.2.7000.7. Please install a valid driver and software application combination.
OK
points
Dolby Advanced Audio error occur
Driver is a very important part of the system of a PC because these programs are the main thing that allows the whole system work perfectly. Without having the right and latest driver, many softwares won’t work or even start.
Dolby Advanced Audio is requiring an older version of audio driver which is not supported. As the software is incompatible with the newer version of driver, you should contact with the software manufacturer for making it compatible with the latest driver.
Otherwise, you can install the older driver right from here.
This means the driver you installed is for a different sound card model. If you downloaded the latest sound card driver from the sound card manufacturer’s website, the version is probably intended for a much newer model or version of the sound card.
If you are using a branded computer like Acer, HP, Dell, and so on, download the latest sound card driver from these manufacturer’s websites instead of downloading it directly from the sound card manufacturer. Try downloading the latest sound card driver from these computer manufacturers:
