andersons
Posted on - 11/02/2011
Strange issue with Domino Web mail and Windows 7. I am running on Windows 7 and using Internet Explorer 8. Everytime I access our Domino 8.5 webmail at home and download attachments that are MS Office ’07 files, they are saved as ZIP files and I have to change the extension to open the document. This does not happen on Windows XP.
Is Domino Web mail is not compatible with Windows 7?
Hi Andersons,
I also encountered that kind of error before and I solved it by doing the following:
Ignore the dialog box that will appear NSD or Domino 8.5 webmail finishes running.
On the dialog box link, click the view message
Your computer screen will be blank and it will show a command window and will open a new dialog box
Click x in the command window and then in the new dialog link box, click return
Restart webmail
If this won't work, you need to make a new shortcut on your desktop with the settings of compatible mode. For example c:programfilesibmlotusnotesnotes.exe and then start in c:programfilesibm'lotusnotesfarmework
I hope it helps.
Zorian
