When I am trying to save a file in Report Creator all time I receive this error message. What is going on here? How this can be getting off of here? Help me.
Report Creator
You don’t have the required permission to save the file.
Don’t have the required permission to save the file
Hello! I have seen your attached problem's image. It's about file save problem. You have to understand that to save a file in Report Creator, you need to run this software as an administrator. At the same time, you have to look forward to the performance of your PC and antivirus issue. Hopefully, you will get it!
Right click on the file and select properties. This will open the properties window. Go to security tab in the top and click on edit in the permissions section Grant write access to your login. Click on Ok and close the window. Now you should be able to save the file.
Hope  this helps.
